Run Vb Script After Hangup
I have uncommonly question!
How to after end of call, when caller hangup, continue script, apropos, run vb script(or other script), and then go to hangup?
After call, I would write into database duration of call.
Maybe, my question is confusing, besouse my english is very bad, I am from Montenegro (ex Yugoslavia).
I see that, but my problem is:
I have two scripts. Script1 is "master script" and work for example 30 sec. When caller broken call after 15 sek, and I call script2,and write into database duration of call, $RV_CALLLENGHT is empty.This is problem!!!! If script1 work 30 sec, and caller is not hangup, goto hangup modul, $RV_CALLLENGHT value is 30, and this case is OK.
Please enable logging by setting the log levels to 10 in VG.INI as per below:
[Log]
VoiceGuide=10
NumberLoader=0
VoicemailManager=0
EmailSender=0
TapiWrapOcx=0
SapiWrapOcx=0
Please post the traces and the VoiceGuide script(s) used.
... the change in VG.INI just only enabled logging...
... it would not have affected $RV_CALLLENGTH substitution...
Still, the main thing is that it's working for you now.
